Been thanked: 4078 times
Richey wrote: Sat May 09, 2026 4:56 am If I understand the video on a new belt I should hit 7ft/lbs at the N mark (installing a new belt). I used a digital torque wrench set to 7ft/lbs and adjusted the tension to where it hits 7ft/lbs at the N mark.
But.... Every video I watch says I should be able to barely move the water pump pulley. At 7ft/lbs I can't, at around 5ft/lbs I can.
What should I do in this case? Set it at 7ft/lbs then slowly a back off until I can rotate the water pump pulley or leave it like it is?
I'm obviously biased, but I'd say trust the tool. It's specifically designed and tested to produce factory-correct tension.
The whole point of the 3D printed tool is to inject an objective, repeatable measurement into the process instead of relying on subjective tests like twisting the belt or seeing whether the pump pulley slips. I'm a broken record on this, but the fact that people often get away with those methods only proves these cars can tolerate out-of-spec tension fairly well -- even if not optimal for the long-term health of all the affected parts. It doesn't mean those methods reliably produce the correct factory tension in my experience -- they can be hit or miss with too many uncontrollable variables in play.
With the tool, if the "N" mark lines up with the rail using the specified 7 ft-lbs, then based on actual testing and measurable force, the belt is within or very close to Porsche's spec for a new belt.
Also, thinking about it, do the "twist the pulley" methods even distinguish between new and used belt specs? Porsche does. The used-belt spec is substantially looser. As an experiment, set the belt to where you can just twist the pulley, then check it with the tool at 7 ft-lbs. I wouldn't be surprised if it lands much closer to the "U" (used belt) range than the "N" range for a properly tensioned new belt.
#541
924SNorth
Just making a post to access the tool, can’t believe I haven’t found this website before !
#542
924SNorth wrote: Thu May 14, 2026 9:44 am Just making a post to access the tool, can’t believe I haven’t found this website before !
I know, right! Tell your internet friends. How'd you finally find us?
#543
MB944TM
Excited to use this on my 944! Thank you, Tom.
#544
Sachilles
On my second 944 timing belt change. Looking forward to trying this tool rather than relying on the twist method.
That you for sharing it.
#545
apple
This seems awesome!
#546
AudiSport
Has thanked: 6 times
Been thanked: 68 times
Printed one out in PLA-CF, the hole that goes over the boss for pivot was real sloppy and didn't seem like it provided a proper pivot to accurately measure the torque. Maybe my cam tower has different size boss/bolt stub.
Also printed with the 12mm triple sq drive which was a bit difficult to use adapters since a 2/3 sets of 12mm triple square I have are 1/2 drive and 7ftlbs/84inch is really a 1/4 drive wrench. Did find a 3/8 drive 12 triple that I had an upsize 1/4 to 3/8 adaptor.....
#547
Wsmcfadden
I just found this group recently. How did I never come across this before! So much information!
#548
Wsmcfadden wrote: Sat May 30, 2026 1:57 pm I just found this group recently. How did I never come across this before! So much information!
Welcome aboard! We are growing every day! Tell the others. :)
#549
Lancy17
Can't wait to give this a try! Gearing up for my first timing belt job on my 86 944!
#550
