1986 951 no start
Real-Time Help, 24/7 — Tuned with Curated Porsche Knowledge
CarBot
Been thanked: 12 times
Tom wrote: the injectors fire straight above the head on the 944, after air has been pulled through the filter, turbo, intercooler and its pipes, and intake manifold -- the injectors sit at the very end of that path, so very unlikely that fuel flowed upstream against the flow of vacuum to pool in the intercooler pipes. A leaking fuel pressure regulator is common, however, and could spread fuel around the intake path. I would be inclined to quadruple check for signs of gas in any of the vacuum lines, including the one to the bypass valve.
You’re right that under normal conditions fuel shouldn’t be traveling “upstream” into the intercooler plumbing, since injection is at the ports. The two ways I’ve seen fuel end up in the charge pipe near the throttle body are heavy flooding with repeated cranking where fuel wets the manifold and can get redistributed by reversion/pulses, and a fuel source that’s actually connected to a vacuum reference line.
On the 951, the most important “vacuum line fuel check” is still the FPR and the damper because if either diaphragm leaks, it can dump raw fuel straight into the manifold via the vacuum hose. If those are truly dry, I agree it’s worth expanding the check to any vacuum lines that see manifold vacuum and could potentially carry fuel if something is misrouted or compromised, including the bypass valve reference line and any tees/check valves in that area. I’d also sniff for fuel at those lines, not just look, because a small amount can be hard to see.
One more practical angle: if there was pooled fuel in the intake manifold from the earlier injector leak/flooding, it can sit and then get pulled into the engine on the next start attempt, making it smoke and stink even if the current mixture problem is actually a vacuum leak or idle control issue. Draining/cleaning the intercooler and pipes you had off is still worthwhile just to remove that variable.
If you want a quick sanity check, pull the bypass valve vacuum line and see if it smells like fuel, then recheck the FPR/damper lines immediately after a key-on prime and a short crank attempt. If fuel is showing up only after cranking, that’s a stronger clue something is actively leaking under pressure rather than just old residue.
#21
zooklm1
Has thanked: 19 times
Been thanked: 58 times
Tom wrote: Thu Feb 26, 2026 3:19 pm @CarBot the injectors fire straight above the head on the 944, after air has been pulled through the filter, turbo, intercooler and its pipes, and intake manifold -- the injectors sit at the very end of that path, so very unlikely that fuel flowed upstream against the flow of vacuum to pool in the intercooler pipes. A leaking fuel pressure regulator is common, however, and could spread fuel around the intake path. I would be inclined to quadruple check for signs of gas in any of the vacuum lines, including the one to the bypass valve.
@CarBot The car starts and idles well. I did check the DME temp sensor and it was in range 3k ohms at 70 deg F. When I removed the intercooler hard lines and air filter housing/MAF, started to remove the J boot (to check vacuum lines) and found that I had not tightened a small clamp. The j boot seemed to have been on the turbo inlet properly (my primary concern). I had a small fan that I used to blow air through the intercooler until I no longer smelled fuel. I put everything back together and it started fairly quickly. As @Tom had stated, I was concerned about the FPR, so I swapped it with a known good spare 3 bar FPR. So I think the leading causes of my no start was incorrect vacuum line routing, poor condition/cracked vacuum line rubber Y connectors and loose hose clamp on one of the small hoses on the J boot. Thank you for your help.
#22
Has thanked: 932 times
Been thanked: 3998 times
zooklm1 wrote: Thu Feb 26, 2026 5:04 pm
@CarBot Can you explain how to tag you with the 'mention' system, where you pick a name from the drop down? I think zooklm1 is having a hard time with that. Also see his latest reply...
#23
CarBot
Tom wrote: Can you explain how to tag you with the 'mention' system, where you pick a name from the drop down? I think zooklm1 is having a hard time with that. Also see his latest reply...
To tag me, start typing @CarBot in the reply box. After you type @ and a couple letters, the forum should pop up a dropdown list of matching usernames. Click CarBot from that list so it inserts the mention properly. If you just type the text “@CarBot” without selecting from the dropdown, it may not create a real mention and I may not get triggered.
Another way that works is to quote one of my posts using the forum’s Quote button and then write your reply under it. I respond when I’m officially mentioned with the dropdown mention or when I’m quoted in a reply. I’m not triggered any other way.
On his latest reply about fuel in the intercooler pipes, I’d still have him recheck for fuel in the FPR and damper vacuum lines right after a crank attempt, and keep focusing on vacuum routing and leaks since it will run briefly but won’t idle.
#24
