Can’t set charging for 85% - it always hits 100%?
KCG_981_Taycan
I have a 2023 GTS ST and I have a ChargePoint charger. The utility company prefers the Chatgepoint to work from midnight to 6 am. By setting the Profile to 12:15 am to 6 am, the car will charge overnight. See attached screen shots from MyPorsche app. The timer shows 85%. But the car still charges up to 100%. What setting am I missing to have it stop at 85%?
toddinmd
Has thanked: 31 times
Been thanked: 59 times
I have a chargepoint and have been using it without issue for the last two years. Your issue is with your timer and profile. The way to fix it is to, disable the timer and set the profile minimum charge to be 85%. That will fix it. Porsche does not make it clear how the two options work.
I only use the timer when I'm planning a long trip that I want the car to be at 100%.
2018 991.2 GT3
2022 Taycan CT4
KCG_981_Taycan
Thanks! I'll give this a try.
jfrstnc
You need to set "minimum charge to be 85%" tike toddinmind says, and enable/tick the Optimized charging option.
At least my '22 Taycan is like that.
julianm
Has thanked: 14 times
Been thanked: 6 times
KCG_981_Taycan wrote: Wed Feb 07, 2024 1:29 pm I have a 2023 GTS ST and I have a ChargePoint charger. The utility company prefers the Chatgepoint to work from midnight to 6 am. By setting the Profile to 12:15 am to 6 am, the car will charge overnight. See attached screen shots from MyPorsche app. The timer shows 85%. But the car still charges up to 100%. What setting am I missing to have it stop at 85%?
Your 6am Timer is turned Off in this screenshot, if you didn’t notice.
2023 718 Boxster GTS 4.0
Rich_911
Has thanked: 2 times
Been thanked: 42 times
I don't mean to hijack this thread, but charging my 2020 Taycan-Turbo is a bit of a mystery. I've always charged to 85%, and when the car was new this routinely gave me 246 miles. I've been diligent with the battery recalls, service, and software updates. Now, when charging to 85% I'm only getting 191 miles - that's a loss of over 50 miles. Has anyone else experienced this?
Regards,
Rich
2008 911 4s
2020 Taycan Turbo S
