9262/1 944 OPRV Alignment tool
Ken944
Thank you for sharing this!
#21
krispfh
Thank you for this. Doing this job next weekend and this thread popped up while searching for the tool.
#22
mike944
Has thanked: 2 times
I had no idea I needed this but glad I found it and the car pokes site. thanks tom for sharing
Maybe this weekend I can knock this out
#23
Has thanked: 932 times
Been thanked: 3990 times
So I printed this tool in preparation for putting my oil console back on and I didn't like the surface of the alignment shaft. I mulled printing it on the resin printer for a smooth body, but figured that wouldn't be much help for the typical 3D printing mechanic. Traditional 3D printers (FDM printers) tend to create a so-called z-seam, formed by little blobs at the start of every layer. Your options are to align the blobs and end up with a seam, or intentionally space out the blobs and end up with random dots on the surface. Here is a random internet picture that shows the traditional options...
Neither of these options are great for an alignment shaft, since the blobs or seams interfere with getting a perfect fit/alignment. So....
Here's my solution! It dawned on me as I struggled to make a perfectly smooth alignment shaft that I could put a tiny notch in the shaft to prevent/hide the z-blobs -- without affecting the tool's functionality at all. [Update: I used this 3D printed tool on my own engine in January '26 and it worked like a champ -- allowed the OPRV to screw in easily after the filter console was torqued in place, and oil pressure was normal after repair.]
Here it is as printed, with the shaft measuring a near-exact 17.51mm (+/- depending on ambient temps). With the notch used as a sacrificial z-seam avoider, it becomes perfectly smooth around the circumference just like its factory counterpart.
OPRV late 944 No Seam Tool.stl
If using an FDM printer, this is the better model to use. I used the Bambu Vision Encoder board to calibrate the print. After calibrating, when printed with Bambu ABS using .16mm layers, the shaft comes out to 17.51 as intended. If you are printing your own, measure it after printing and scale the X and Y dimensions in your slicer up or down as needed to get to 17.51. Once you do that, I'd argue it's every bit as good as the factory tool. :mrgreen:
#24
There seems to be some interest from folks who want to buy one of these from me. For the time being, I'll make sell them for $10, plus $5 shipping (plus tax for California residents) to any registered Carpokes user in the US. Shipping outside the US is possible, but would cost more than it's worth I fear. If you want one, send your user name, email for PayPal invoice, and mailing address to me at [email protected] Thanks all. :angel:
#25
