Oil Pan Gasket - While I'm in there...
- zooklm1
- Has thanked: 19 times
- Been thanked: 60 times
Did you have problems getting the fittings to seal (hence the use of the Seco seals) or as a preventative measure? On the wrenches and vise clamp, did they give better performance over regular tools or primarily keep from scratching up the anodize on the fittings? I have used steel AN style fittings on high pressure ( 1,000 - 3,000 psi) hydraulic systems and never had problems with leaking at the face seal.
Thank you.
Thank you.
Yes - I had some me air bubbles when testing the connections in a water bucket, so Pegasus recommended the Seco seals
Yes - the AN wrench and vice adapter provided a better grip
1986 951 - Silicon Valley
