3.0 16V engine mods, etc
Thom
The First Carpoke!
Has thanked: 139 times
Been thanked: 156 times
SirLapsalot wrote: Thu Mar 06, 2025 9:59 amWhat do you guys think about the G30-660 with 0.83 A/R for an 8V 3.0L running 1-1.3 bar of boost?
That sounds like a recipe for massive mid range through minimal torque lag and should flow just enough for whatever an 8V head with the 9R cam can offer with the stock inlet and IC. You don't mention the exhaust but I'm sure you will use nothing smaller than 3".
'90 944 turbo
#261
chris white
Been thanked: 175 times
I can cleap up a used K26/6 if you want. Painting the compressor housing red will get you more power. $10.
#262
chris white
he is a map for the Tial set up i use for 3.0 street
figuring a 1.5 bar of boost at 6500prm you will be in the 83% efficiency range.
At 1 bar, 3500 you are down to 82% efficiency.
So its got you covered at both ends of the performance range.
Screenshot 2025-03-07 100900.jpg (105.54 KiB) Viewed 5338 times
#263
Boostfeen
Been thanked: 4 times
Putting several exhaust vents in the hood really helps get things moving the right direction in regards to messing with inner bumper flow paths on the 951 if it’s a street car then there’s very few tasteful looking paintable options for this….
#264
gruhsy
Has thanked: 48 times
Been thanked: 83 times
That’s a really efficient compressor map.
First I have seen in the 80%.
I may just have to add one from you to one of my builds.
That of course will have to go with your cam time machine piece you made and I will guess a Link of some configuration.
Still going to do a twin scroll but that the plus side of having so many engine blocks now.
chris white wrote: Fri Mar 07, 2025 7:14 am he is a map for the Tial set up i use for 3.0 street
#265
chris white
gruhsy wrote: Fri Mar 07, 2025 8:53 am That’s a really efficient compressor map.
it is impressive, teamed up with a stainless center section with replaceable mounting base and the great Tial SS hotside I think its a winner.
#266
Bergerac
Has thanked: 21 times
Been thanked: 126 times
chris white wrote: Fri Mar 07, 2025 2:37 pm
If you offered that with a Vband crossover and downpipe package you'd have my attention.
#267
chris white
Bergerac wrote: Sat Mar 08, 2025 9:11 pm
just might be something I am working on......
#268
Bergerac
chris white wrote: Sun Mar 09, 2025 8:17 am
I sent you a PM Chris, not sure if theres a better way to get in touch
#269
Has thanked: 950 times
Been thanked: 4072 times
Bergerac wrote: Thu Mar 13, 2025 8:47 pm
Paging @chris white... You can also reach him through his website I'm sure.
https://944enhancement.com
#270
