As the title says, I have bought a secondhand clubsport steering wheel to go in my 968, replacing the oem airbag wheel. However, when looking at which hub to use, there seem to be different versions, and I cant seem to find the difinitive answer to which one I need.
There seem to be two hub versions and both claim to fit a 968, like shown below. Can anyone confirm which hub I need?
Thanks, Alex
download/file.php?mode=view&id=15574
Which hub do I need to install CS wheel in my 968
- Latitude48
- Has thanked: 72 times
- Been thanked: 61 times
You need the hub in the bottom picture. Your steering column multi-function switch will work fine; you can get the horn working by inserting the horn contact switch, 928-652-104-01 (currently listed as unavailable, but you might find one at Pelican parts, etc.) into the hour-glass hole in the faceplate of the switch. The brown wire from the clockspring can be attached to the rear of the contact with a suitable terminal. Deactivating the airbag light can be performed in various ways.
Have fun.
Have fun.
Tom Pultz
Both of those hubs are Atiwe type hubs, if you get one that will work on a 964/993, it will work on a 944/968.
You screw in a horn slip ring from a regular steering wheel, which is the difference between the two that you see.
Source: Just did this to my car, I swapped in an Atiwe wheel
1991 944S2
2000 540iT/6
Insta: stitch2k1
2000 540iT/6
Insta: stitch2k1
@Motosport Did you get this figured out? I just completed a similar project on my 89 944 S2 including adding a resistor to fool the airbag system. Happy to share my notes if helpful.
Motosport wrote: ↑Sat May 11, 2024 4:54 pm As the title says, I have bought a secondhand clubsport steering wheel to go in my 968, replacing the oem airbag wheel. However, when looking at which hub to use, there seem to be different versions, and I cant seem to find the difinitive answer to which one I need.
Thanks, Alex
Reluctant geek, weekend wrencher, marketer, enthusiastic father of two, husband of extremely patient wife.
‘24 Cayman GTS
‘19 Cayenne e-hybrid
‘11 Boxster Spyder
‘89 Porsche 944 S2
‘24 Cayman GTS
‘11 Boxster Spyder
‘89 Porsche 944 S2
