I've always heard good things about EPS, but have no idea about their trailing arms. If you are hearing that they are problematic, may be best to avoid them and put your OE arms back on until you can get exactly what you want. I don't think trailing arms are a high wear item but can't say for sure. Usually the coffin arms are what you hear about wearing out.
Back to EPS. They make a long wearing clutch disk that I thought I'd get if I ever needed to replace the clutch. It has more material in contact with the pressure plate and flywheel that the OE disk does and that makes some sense to me. I also like their roller bearing IMS bearing. A roller bearing just makes more sense to me than a ball bearing for some reason. More contact area on the bearing I suppose.
987S Suspension Refresh
- aboyandhisdog
- Has thanked: 136 times
- Been thanked: 57 times
- vitaminc
- Has thanked: 35 times
- Been thanked: 51 times
This scares me: EPS Control arm snappedaboyandhisdog wrote: Mon Jan 29, 2024 8:48 am I've always heard good things about EPS, but have no idea about their trailing arms. If you are hearing that they are problematic, may be best to avoid them and put your OE arms back on until you can get exactly what you want. I don't think trailing arms are a high wear item but can't say for sure. Usually the coffin arms are what you hear about wearing out.
For now I'll probably stick with what's in there. I just wanted all new bushings. So it goes.
From that thread:
05 Boxster S
- aboyandhisdog
- vitaminc
Amazingly, I am not done yet. Getting closer though…
Refinished brakes Front back together Getting to the rear shocks and control arms was a major PITA. Part way through reassembly on one side. After finishing that side up, it’s on to the other side in the rear and finish up with a brake bleed and alignment.
05 Boxster S
- Has thanked: 952 times
- Been thanked: 4078 times
Those calipers look great. Is that paint or powder coating? Did you send them out to have them done? Sure looks professional!
- aboyandhisdog
- vitaminc
Thanks! After a lot of cleaning, I used a kit from G2, applied the stickers, and then topped with some caliper specific clear coat. It’s not perfect, but when the wheels are on it will definitely be good enough!Tom wrote: Wed Mar 06, 2024 7:30 pm Those calipers look great. Is that paint or powder coating? Did you send them out to have them done? Sure looks professional!
05 Boxster S
- vitaminc
Closing in on it now…
Got the spring transferred over from the right-rear shock onto the new damper. Those old dampers were very crusty. I expect this corner will go a bit easier as I - hopefully- learned some things from the other side
05 Boxster S
