1987 951
170K miles
Evergreen Raptor Turbo, Tial 38mm WG (.8bar spring), LR MBC (all installed in the past few weeks)
Fabspeed downpipe (Jet-hot coated), Fabspeed exhaust with "performance cat"
Innovate WBo2 Gauge, Autometer Boost gauge
3-Bar FPR
LR MAXX DME and KLR chips
F9 Sport DME w/ ODB+
Rebuilt KLR
Valvoline VR1 20w 50 (changed often)
Peak Blue Coolant (Porsche pre-1996)
Compression test 1-145; 2-90
Pulled the head yesterday and confirmed HG failure on cyl 2 (cylinder was also wet and noticeably cleaner)
HISTORY: Car purchased Nov 2022. Vehicle has pretty good documentation from 2000 to now. Head was rebuilt in 2016. Unfortunately, the receipt was one of those diner style "let me take your order" written receipts from wherever the work was done - it didn't even list the name of the shop. One of the line items was written "skim head", but it didn't say HOW MUCH was skimmed. A Widefire HG was used, which failed. When I received the car it had an eBay style MBC, with NO aftermarket chips (or CV), so I'm assuming it was running pretty lean on boost - and for who knows how long. I removed the eBay MBC, put in a new CV and plumbed to factory routing. The car ran pretty good, but there was always a hesitation when just getting into boost. I replaced all fluids when I got the car and it never overheated under my ownership in the past year. It was upon installing the new turbo/WG/MBC setup and putting the pedal to about 1/2 throttle where I immediately had a loss of power, the motor bogged down and my AFR went to around 16/5-17. Before that, idle was between 14.7 - 15 and under boost it would go to around 12.5
The purpose of this post is "which HG should I get?" My main conundrum is that I don't know how much was skimmed in the first head rebuild. I'm going to drop the head at a machine shop and I'm sure they might skim it again. I'm afraid that enough material will have been removed to not allow for another factory style HG (including WF HG). If so, that leaves me with aftermarket or "performance" HG's. I watched Tom's video where he compared a few HG's for his project but it mainly compared the different brands and types but not to calculate which thickness to go with.
My goal for the car is for a RELIABLE 300-350 HP. I have a Vitesse MAF kit coming in a few weeks. This is not a track car - more for "spirited" runs with the local PCA chapter - I need to keep up with the Cayman S's on the straights. Other than that, it will be driven on sunny days to work, local cars & coffee meetups/car shows. I know the Cometic metal HG's come in various thicknesses and I have no idea which thickness I need - or if they are just overkill.
I truly appreciate any help and advice! I don't want to have to go through this again for a very long time.
