951 Resurrection - after 7 years of storage
Meine44
Been thanked: 6 times
sletcher wrote: Fri Jul 10, 2026 8:00 am Hardline PS clamp is 10 x 15 clamp pn 99951111602
I think any 15mm diameter clamp would work, but hope that helps. I order nuts, bolts and clamps from Belmetric.com , they have p clamps there too. I think you need an m6 mounting hole.
Yes, that is helpful, thank you! I will add this to the list of items to source from the local hardware store.
Sometimes I get stuck searching the PET parts catalog and forget that I have the ability to remove small parts like this and bring them into a brick-and-mortar store for comparing :oops:
#41
Has thanked: 949 times
Been thanked: 4063 times
Meine44 wrote: Thu Jul 09, 2026 8:54 am Also, I would appreciate any help identifying two small pieces that I need to replace:
-The clip that holds the rear interior trim piece to the body of the car. Two are broken and one is missing. This clip holds the interior trim / leather side panel to the inside of the trunk.
-There is a hard-line clamp near the oil pressure sender that has disintegrated - the rubber is thrashed.
You can get those cushion clamps at a local hardware store, or amazon, though the ones Porsche sells are higher quality by a country mile (thicker rubber, thicker metal)... That panel clips are available, but you may need to re-secure them in the panels (JB Weld, etc.)... I 'think' your picture shows this style...
