Those spots on old instrument clusters....
miggytosh
Has thanked: 35 times
Been thanked: 22 times
Happy for this thread as my S2 is suffering from this issue and it’s one of my spring to-dos.
Reluctant geek, weekend wrencher, marketer, enthusiastic father of two, husband of extremely patient wife.
‘24 Cayman GTS
‘19 Cayenne e-hybrid
‘11 Boxster Spyder
‘89 Porsche 944 S2
#21
NCGermerican
Has thanked: 143 times
Been thanked: 97 times
Ajay213 wrote: Sun Mar 03, 2024 10:27 am I do have the Lutz Auto circuit replacement sitting in a box here, the ribbon on mine is very shaky - the replacement from a 2nd hand cluster wasn't much better.
I've almost hit the purchase button on the Lutz kit a few times but never did. Please keep us updated when you install it and let us know how the install was and how well it works!
#22
breilly951
Has thanked: 4 times
Been thanked: 18 times
Hi all, I thought I would share the procedure and results for removing the lens and eliminating the white spots on my 951 binnacle. In hopes of my eventual number coming up for one of Toms' 911 style bezel & LED kit, I thought I would do some preliminary prep work for the install.
Removing the clear lens was not too hard and I was able to get it off without cracking it. I heated the edges up a little using heat gun on low and then used a very thin flat head to "gently" pry up on the lens and slowly going around the entire perimeter of the binnacle. I did this several times and it eventually pulled free. For me, not rushing the process was key.
My binnacle also had the usual white spots so I used Toms' heat gun method to remove them and it worked great. I removed the instruments from the binnacle and then used low heat and kept the gun moving over the entire area for a few minutes seemed to do the trick. The texture remains and the spots are gone. I also plan on using Griot's trim restoration before I put it back in the car.
Here are a couple of photos to show before and after results. I believe patience is the key to success for these two tasks.
Bruce Reilly
Ins Panel.jpg (230.13 KiB) Viewed 1868 times
#23
Has thanked: 949 times
Been thanked: 4061 times
Very glad to hear you got the clear lens off without too much fuss. The black binnacle stuff looks fantastic with just heat, but try the Griot's Trim Restorer stuff too, in the green bottle. Between the heat and the Griot's stuff, it makes the binnacle look better than the day it left the factory. Did you remove the light guard trim at the bottom -- where the arrows are pointing in the picture below? It just loosely clips into place and comes off without tools once the clear lens is removed. Behind it are where the light tunnels stick up, and where you either will or will not have another smaller plastic strip behind the light tunnels. If you have a chance, can you post a picture with that front strip removed, so I can see what's behind it. Still trying to map which clusters have that extra strip and which don't. (It's the kind of valuable info that gets a guy bumped up on the list, just say'n :angel: )
breilly951
Tom and all,
Here are a couple of photos Tom asked me to post showing the additional plastic strip used on my 1986 951 binnacle.
#25
MoeMonney
Been thanked: 38 times
Just rub away with WD-40 and a microfiber towel on the interior for the cluster. Comes right off and leaves the cluster looking like new.
On the lens use PlaticX from meguiars.
#26
Latitude48
Has thanked: 106 times
Been thanked: 115 times
I pulled the clusters out of the 951 and S2 in preparation to fix the broken odometer gear in the S2, and install the 911-style gauge kits. The surfaces in both clusters looks uniform without white spots, but it doesn't look really dark black either. It has what I would call a bit of a fuzzy look to it, which might not be too durable once the binnacle is removed. I'll have a better idea once I get them back from N. Hollywood Speedometers and remove the binnacles. I'm kinda leaning towards flat black paint, but may try the Griot's ceramic trim restorer first as this might be good treatment for the cluster cover trim.
Anyone else have a cluster that seems to have a very faint fuzzy texture to it?
Thanks.
Update: I ordered the Griot's Ceramic Trim Restorer. I got free shipping as a first time purchaser after signing up for the newsletter.
Tom Pultz
#27
Latitude48
And speaking of clusters... when the trim around the cluster that contains the central HVAC vents was removed I noticed the 951 seems to be mostly missing what was once some type of foam seal round the inner rectangular vent area where the plastic vent piece mates. I guess I'll scrape off whatever remains and install some foam door edge molding or something similar. The S2 does look to be mostly intact, but I may replace it as well since all this foam just wants to fall apart if you look at it wrong, ha, ha.
Tom Pultz
#28
