Attached is a downloadable PDF which details the process for replacing the a/c compressor and condenser on the late model 944 cars.
944 A/C Compressor/Condenser Replacement
- Has thanked: 485 times
- Been thanked: 2276 times
You need at least one post on Carpokes to see and download files.
I'm new to this too, but from what I gather, you want to considering flushing the system if your compressor had failed (sending metal debris through the system), or if you are unsure of what type of oil/how much is in the system. In those cases you want to flush and start clean.
I have heard you can backflush the evaporator through the dryer line by the driver headlight, but I have also heard you can't do that with systems that have expansion valves (which ours does) - so I would like confirmation on that..
