I just had my 2013 Panamera GTS in for Service --- the dreaded Suspension Fault. They replaced a locked up compressor and all has been good. But after spending $3000 on that repair I was not about ready to cough up $880 for Engine Air Filter replacements. I did some Google searching for some DIY info and not much was available. It looks form what I can gather there are 3 filters to be changed. Two are located in front of either wheel well - requiring the wheel and wheel well liner removal. The 3rd filter seems to be located in the front hood scoop/bumper.
I guess I can now understand the price considering you need to pul the bumper off to get at the center filter. Has anyone done this as a DIY? I'm fairly handy and think I should be able to do it myself in a weekend, but would like a little reassurance from someone who has completed this project.
At the same time, I'll plan on replacing the low-tone horn because right now our panny sounds like a clown car when you hit the horn (high tone only)
Thanks in Advance
Changing Air Filter in Panamera GTS
That is what has me confused. The dealer quoted for 3 engine air filters - 2 of one type and then 1 of another.
I just double-checked the estimate and it actually lists the part #'s. So it lists the 2 can filters from the wheel wells and the rectangular one from under the bumper. At least they've provided me with part #'s to do my own work I'll update this post when i finish this job.
Your GTS only has the wheel well air filters, this video explains all of it
$80
https://www.fcpeuro.com/products/porsch ... e-lx2974kt
All other 1st gen Panamera's 2010-2013 have 1 big filter behind the front bumper
$80
I think the GTS has all 3 - see the pic for the estimate I received from the dealer below.911LIMO wrote: ↑Fri Mar 29, 2024 1:15 pm Your GTS only has the wheel well air filters, this video explains all of it
$80
If I look up the part #'s it links to the 2 cans and the long box filter :shrug:
sorry yea you have a 2013 GTS my mistake
part #'s
https://porsche.oempartsonline.com/oem- ... 9711013032
https://porsche.oempartsonline.com/v-20 ... n--filters
part #'s
