Prelude
Have you ever taken anything apart and wished you had taken better notes or photos? I have.
This post is part of a continuing series of posts that detail the internal construction of various things. This is not intended to be step-by-step instructions for repair/removal/disassembly/etc. Rather, I hope this post (and future posts) can serve as a reference for people who would like visual clues in making their own repairs.
See Also...
What's Inside: Door Handles
Window Channel Tab and Door Skin Crack
Left Side (Driver's US) Door
I never had the door latch mechanism apart (I'm the second owner since 1999). I believe this was the first time any of the door latch/handle stuff was apart since Germany.
Door Lock Motor
Behind the door lock motor is another black plate that probably makes "slim-jim" style door lock attacks slightly more difficult. I don't have separate photos of its removal, though it is straight forward.
The ball end of the nylon rod (that connects the power lock motor to the door latch mechanism) has a small clip that helps keep the ball end secured on its ball. That clip is known to fail and break away, which has happened here. If the nylon rod falls off its ball, the lock/unlock functionality also fails, naturally.
This nylon rod does not have distinct left/right part numbers.
left or right pn: 944-537-511-00-M100
Door Latch Block
Aft Window Channel
It should not be possible to remove the aft window channel quite so easily. The part circled in green is supposed to stay attached to the door. It is held on with two spot welds, both of which had failed on mine. For better photos of that part, and more information, see Window Channel Tab and Door Skin Crack.
There is a fastener that secures the black window channel to the part circled in green (and another one at the bottom of the channel, not shown). It may be possible to remove that fastener without removing the window. But removing the window is easy. Consider avoiding the hassle and just get it out of the way.
Door Interior 01
The (very dirty) nylon part circled in purple has a separate left/right part number. I'm not sure which is which.
477-837-505-A-OEM
477-837-506-A-OEM
The black plastic part circled in orange is called the "Door Latch Socket". It does not have distinct left/right part numbers.
Left or Right pn: 999-168-004-40-OEM
Door Interior 02
A slightly different perspective.
Door Handle Removal
Interior Door Pull
Complete Door Latch and Handle, Exploded
What's Inside: Door Lock & Latch
- danmartinic
- Has thanked: 1 time
- Been thanked: 9 times
My door handle is not "springing back" very well these days... often sticks in open position & have to nudge it back.
Is there a simple lubrication or cleaning fix? Is it tricky to remove the handle?
- danmartinic
I imagine I can get to this spring and lubricate it?
Do I have to remove the door panel to get to this or is there a way from the outside?
You can easily get to that mechanism without removing the door card. There is a screw on the side of the door in alignment with the door handle that holds it in place, after removing that you can slide the handle either forwards or backwards (I forget) and pull the handle outwards (it will look like the picture usury posted titled "Door Handle Removal").danmartinic wrote: ↑Tue Jan 10, 2023 10:31 am I imagine I can get to this spring and lubricate it?
I spray cleaning solvent and lithium grease this way every once in awhile to keep the handles easy to open.
- danmartinic
